Misfire Question
Old Aug 1, 2010 | 04:52 PM
rabenson92's Avatar
Default Misfire Question
Hi
I installed the K4 turbo in my car some time ago. When I would step on the throttle it would adjust the timing I believe due to running to lean. I learned not to step on it for quite some time. Recently I installed larger fuel injectors with a new fuel pressure regulator. Now when I step on the throttle I'm getting misfire codes (which I was not getting before installing injectors/regulators). Since the misfire started after I installed the new injectors I'm not sure that I have bad coil packs. I'm curious if anyone has ideas on what I should check. I did install new NKS spark plugs. Do I need to gap them tighter/wider for running more boost?
Thanks!
Russ
Old Aug 2, 2010 | 12:06 PM
shortyxc's Avatar
Moved to other thread....
murdox
Jan 19, 2012 04:59 PM
Bligh
Dec 13, 2010 08:56 PM
Colin1
Feb 14, 2010 01:13 PM
Heber
Jan 13, 2010 03:16 PM
zoidberg3.0
Apr 1, 2009 06:47 PM
