Misfire's
I have a 98, with the 2.8. Last Sept I was getting the codes for misfire in 2 & 4. Replaced the coil pack, wires and plugs. I'm getting the misfires again in 2 & 4 after about 5,000 miles. What could be going on?
Look for oil leaks from the valve cover gaskets. You didn't say whether you've changed plugs either. BKR7EKUP plugs are $3 each at Advance Auto - gap them to .032" and see how things run. Long shot possibility would be injector problems but that's doubtful. Check the grounds on top of the valve covers too - clean/sand/refresh those too, just because.
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
