Misfire's
Old May 1, 2014 | 06:26 AM
RedA4guy's Avatar
Default Misfire's
I have a 98, with the 2.8. Last Sept I was getting the codes for misfire in 2 & 4. Replaced the coil pack, wires and plugs. I'm getting the misfires again in 2 & 4 after about 5,000 miles. What could be going on?
Old May 9, 2014 | 10:15 AM
ImTheDevil's Avatar
Look for oil leaks from the valve cover gaskets. You didn't say whether you've changed plugs either. BKR7EKUP plugs are $3 each at Advance Auto - gap them to .032" and see how things run. Long shot possibility would be injector problems but that's doubtful. Check the grounds on top of the valve covers too - clean/sand/refresh those too, just because.
Old May 10, 2014 | 09:00 AM
RedA4guy's Avatar
Changed plugs and wires also, but I gapped them to .060 as the book said to. I will re-do to .032. I did replace a valve cover gasket last year.
Old May 10, 2014 | 09:24 AM
ImTheDevil's Avatar
Yeah the book is wrong - first time I did plugs, I went with .060 and it wouldn't even start. Gap them to .032 and you should be much better.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
