misfires
Today I was driving on the freeway and was feeling a but spirited so i down shift to fourh and goose it, i shift into fifth and then my cel starts flashing. I have new coil packs and old plugs. any other possible cause for random misfires while driving?
ps the codes were p0300 and p0302 multi cylender mifire and cylnder number 2 misfire.
You should know the drill. Replace and gap the plugs and then rotate the packs to see if the misfires follow the packs.
Its kind of like lather... rinse... repeat. It should be second nature by now
Start of simple and work your way up. Just hate it when people spend money on things that are rarely the cause. Mainly 4 new coilpacks when they chip it when all they needed to do was lower the gap on the plugs and replace the Maf when it has nothing to do with the MAF.[:@]
does it make a differance that it happened and then went away. it happened for at wot open throttle long enought to throught the code then about 50ft later it ran fine. I am changing the plugs this morning with some bosh coppers
