Mismatched Wheels & tires Harmful?
Old Dec 8, 2010 | 11:28 AM
dlcain's Avatar
Default Mismatched Wheels & tires Harmful?
Had a front left flat tire on my A4 Quattro yesterday. Unfortionatly it wasn't the tire and was a hairline crack in the wheel that had grown larger It is an RS6 type wheel 17" with 225/45R-17 tires. Instead of putting the small spare back on, I installed my original wheels and tires just on the front left and right which are 295/65R-15's. Because I'm all wheel drive, just wondering if I'll be okay to run this way until I can get a new wheel?
Old Dec 8, 2010 | 11:49 AM
mmdambro's Avatar
From what I understand about the quattro system, it is not good to have any discrepancy in wheel size and yours would be a pretty big one. Don't drive it like that for very long.
(I just posted a similar question and my discrepancy would only be 1/4 of an inch)
Old Dec 8, 2010 | 02:45 PM
bradtyler02's Avatar
^he is correct.
Old Dec 8, 2010 | 03:12 PM
CCA4's Avatar
Anything more than about 3% of the rolling diameter of the tire will eat up the center diff. For example, the diameter of a *new* set of 225/45 17's is 24.972". 3% of that is about 3/4". So depending on the amount of wear you have on either set, you could be in trouble. If you have no choice but to drive like that for a day or two I don't think your car will blow up and the wheels will fly off, but I wouldn't press your luck any more than that...
EDIT: Sorry, I just re-read that post and realized that it was kind of cryptic and not finished. So the point of all that math was that if the diameter of any of your tires is more than 3/4" +/- any of the others, it will cause excess wear on the center diff.
Old Dec 8, 2010 | 04:39 PM
NickBroderick's Avatar
Chris your reason for editing. Hahahaha.
Audi doesn't recommend even using different tread patterns, so don't do it for long.
bigatstyle
Nov 9, 2012 08:29 AM
erroob0977
Jan 25, 2011 06:47 PM
bigdig712
Feb 6, 2009 12:49 PM
m5racer
Aug 10, 2006 12:27 PM
fabricator
Apr 11, 2005 01:32 AM
