is it my cv joint or control arm?
Old Jan 11, 2011 | 04:14 AM
zroy16's Avatar
Default is it my cv joint or control arm?
lately ive noticed that something near the front passanger wheel clicks and it happens when i go around sharp corners and when im leaving the stop position. ive been told that it could be my CV joint but i want to know what it is for sure before i start to replace things that dont need to replace. could anyone help?
Old Jan 11, 2011 | 09:07 AM
Andrew149's Avatar
thats correct ive had that issue with my a4,a8 and now my gti the best way to tell is to take the wheel off inspect it if you dont catch it than jack both sides of the car up turn on the car and turn the wheel
Old Jan 11, 2011 | 10:02 AM
dragonrage's Avatar
It's your CV joint.
Old Jan 11, 2011 | 10:19 AM
Andrew149's Avatar
Originally Posted by dragonrage
It's your CV joint.
yes and no, it also can be the control arms or tie rods
Old Jan 11, 2011 | 02:09 PM
dragonrage's Avatar
Those do not sound anything like a CV joint when they're bad. Not even close.
Old Jan 11, 2011 | 02:21 PM
Dallas09's Avatar
CV Joint= Clicking, especially when turning with the wheel at lock. Control Arm/Ball Joints= Squeek at low speeds and initially and turn into clunking noises
Sounds like classic CV Joint
Old Jan 11, 2011 | 05:18 PM
zroy16's Avatar
okay well i'll start out with replacing my CV joint and if that doesnt fix it then i'll replace my control arm thanks for the help
Old Jan 11, 2011 | 06:18 PM
Andrew149's Avatar
Okay explain this on my gti when i hit a bump the car sounds like the wheel hits the fender wheel really hard also if i hit a pot hole hard it sounds like a flat tire for few minutes and its really loud and when i turn the wheel it clicks alot,,, cv joint? i checked mine its all greased up with no leaks
Thomas212
Feb 16, 2011 04:04 PM
ihickok0403
Oct 31, 2010 12:53 PM
Pjbrof
Sep 10, 2009 12:34 AM
mustang196718
Nov 7, 2008 02:28 AM
Heinzanova
Oct 26, 2005 08:45 PM
