My Giac is Immobilized??
Old Jun 4, 2008 | 10:44 PM
fuzz_duster's Avatar
Default My Giac is Immobilized??
So I bought a used Giac from a guy on AZ. I got it today, and bolted it on, Turned ignition to ON position for 5 minutes, went to start the car, it started, idled at 500 RPMS, sputtered, and died. Tried again, same thing. So I searched and found out that its most likely immobilized, being as its still tuned for his VIN. [sm=bs.gif]
ANYWAYS, my question is this: Do I HAVE to take it to a Giac dealer (only one in my state, thats 250 miles from me...), or can I buy a Vagcom and download the Giac software off the site and flash it myself?? I know the shop charges an hours labor to flash it, which will run me about $250, and in that case, I could have bought a brand new chip, already flashed for me, for $500, instead of dropping $450 on this one, then another $250 on a seperate flash....[:@][:@]
any help is appreciated.
Old Jun 4, 2008 | 11:15 PM
hiwords's Avatar
Default RE: My Giac is Immobilized??
that's weird. usually it should just work. does your ECM have the same part number as his?
Old Jun 4, 2008 | 11:33 PM
yep, I took the time to read each part number side by side, and they are perfect. He did have the exact same car as me.
From what I can gather all Giac chips have the ability to go into immobilizer mode when installed into a new car. Something about theft protection or something? Idk....don;t think it could be anything else. I stuck the OEM chip in right after and she fired right up.
Old Jun 4, 2008 | 11:58 PM
hiwords's Avatar
well looks like of you go to giac. vagcom won't solve your problem
Old Jun 5, 2008 | 12:25 AM
Bogie's Avatar
That's definitely gotta be a GIAC related issue. The ECUs for 1998.5 didn't have immobilizers from Audi.
Old Jun 5, 2008 | 12:32 AM
well then wtf. The guy was aparently using it up to 2 days before he shipped it to me, and he was very credited on AZ as a good seller with 100% positive feedback.... So if it doesnt have the immobilizer, then I wonder what could be causing it. I'll try it again tomorrow I guess. But if you guys have any other info, its all greatly appreciated! I'm kinda out $520 right now...
Old Jun 5, 2008 | 01:09 AM
jibberific's Avatar
dude, Evolution is a GIAC dealer. they claim to be the biggest one in the state i think.
Old Jun 5, 2008 | 01:48 AM
I just wish it would work so I don;t have to take it in and pay another $250 bucks or whatever for them to flash it in 10 minutes
Old Jun 5, 2008 | 12:13 PM
Mike-2ptzero's Avatar
Does the car run fine with the ecu you had in it before?
Also sounds like you might need to do the throttle adapt again since 500rpm is a bit too low.
alishmee
Nov 13, 2010 06:24 PM
mikekehler
Oct 6, 2009 12:38 AM
Brandon2000s4
Sep 14, 2006 03:08 AM
dan
Jun 18, 2006 10:28 PM
