My very own update thread
Old Oct 16, 2013 | 03:01 AM
  #391
morpheous's Avatar
Originally Posted by MetalMan
The idle would float up and stay there for a little while, and sometimes it would be okay. I changed/checked almost everything attached to any vacuum sources, and swapping out the 034 billet PCV valve for an OEM one fixed the problem!
1 x Cooling Hose Flange Single Outlet Meyle $15.48
1 x Water Flange O-Ring Victor Reinz $1.44
1 x Water Pipe O-Ring $2.91
1 x Breather Hose Kit, AUG/AWM/AMB B5/B6 Audi A4 & Volkswagen Passat
- Include Check Valve: 034 Billet Check Valve
I ordered my PVC system, along with the 034 Billet Check Valve, should i be worried? Should i return it and get a OEM platic one?
Old Oct 16, 2013 | 06:13 AM
  #392
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I did a little more testing.
I unplugged the VSS and made up two jumpers. One going from the VSS signal output to the plug signal input.
I connected two separate grounds going from the sensor and plug directly to the battery's negative terminal. I put the wheel back on and gave it a spin while my brother watched the speedometer and VCDS output with no change.
Old Oct 16, 2013 | 08:53 AM
  #393
Clayson's Avatar
I'm sorry BaseDrifter, but your thread is quite entertaining Yet VERY informative. Oh, and I believe I have a headlight switch you can have if you want.
Old Oct 16, 2013 | 09:52 AM
  #394
bshusted's Avatar
Have you tested for continuity from the sensor to the cluster? How does the plug for the sensor look? If it has one of those rubber boots, pull back the boot to look at the connections on the back of the plug.
Old Oct 16, 2013 | 10:50 AM
  #395
MetalMan's Avatar
I don't know that everyone will have this problem with them, but if you do some searching online you'll find that others have had problems with this part.
Old Oct 16, 2013 | 11:06 AM
  #396
morpheous's Avatar
Well, the part is cheap Audi B5 A4 Quattro 1.8T Search SiteSearch 035103245A ES#257303 Bleeder Valve - 035103245A
Even cheaper at genuineaudiparts.com:
2001 Audi A4 Quattro Parts - genuinevwaudiparts.com
So after doing research, I'll have to make a decision to use OEM or this 034 after market one. The labor isn't cheap
Old Oct 16, 2013 | 04:17 PM
  #397
Yep, had continuity from sensor to input on cluster. It does have one of those boots just like the reverse plug I sent you. I guess today I'll go back and check that out. But both wires have continuity.
Text does a really poor job of portraying my level of frustration with this. There are only so many components in this system. I've checked or replaced basically everything. At what point do I call over a spirit talker?
Old Oct 16, 2013 | 05:07 PM
  #398
smittylube's Avatar
Dont you have another cluster you could try? otherwise I would suggest as it was earlier to try a lab scope and see what you get from the sensor. If you made a jumper - perfect use that to verify the sensor is sending something to start with.
Old Oct 16, 2013 | 05:37 PM
  #399
I sold my old cluster a few weeks ago.
The reason I keep going back to the wiring is because the speedometer has worked intermittently. A few days ago the speedometer worked for 15 miles. No fluctuation, accurate speed confirmed by my GPS. I parked the car and it didn't work when I started the car again.
Old Oct 16, 2013 | 07:07 PM
  #400
smittylube's Avatar
Dont get thrown off course- it is all basic check or verify the basics first.
may be something loose inside the cluster? that pin was pretty well tweaked
