N249
Old 10-28-2009, 06:31 PM
whitejeepXJ's Avatar
Default N249
Where is it? What does it look like?
I changed my alternator and now I get p1287 - Boost Pressure Control Valve N249: Open Circuit
Thanks,
Mike
Old 10-28-2009, 06:36 PM
dragonrage's Avatar
diverter valve solenoid... think it's under the intake manifold?
Old 10-28-2009, 06:58 PM
I think so too.. I was wrenchin under the manifold when I changed out the alternator... does this mean something is leaking or the connection is bad?
Old 10-28-2009, 07:46 PM
dragonrage's Avatar
My guess is you broke one of the connections to it. The vacuum ones are fragile, and the electrical one probably is easy to break as well. Open circuit sounds electrical to me.
Old 10-28-2009, 08:03 PM
Code is GONE. I played around with all the plugs.. basically pushing them in tightly... Re-scanned and nothing!
Awesome, thanks guys!
Mike
Old 10-28-2009, 09:44 PM
TeeterTawter's Avatar
under the intake manifold closets to the front, you can bypass it btw, just keep it plugged in electronicly and you won't get a code, also plug the vacum ports on it.
Old 10-28-2009, 11:02 PM
dragonrage's Avatar
And the reason to bypass it would be...?
Old 10-28-2009, 11:22 PM
they cost alot, kinda usless part imo, and mine failed on me. so i just connected my dv directly to the intake manifold.
Old 10-29-2009, 12:21 AM
dragonrage's Avatar
If they're useless, why would Audi have used them?
jhsoccerodp
11-01-2021 08:03 PM
l88m22vette
10-02-2008 05:06 PM
themysteryman83
06-06-2008 07:09 PM
MeanAudiA6
04-07-2008 06:03 PM
pimphell
03-26-2008 12:09 AM
Quick Reply: N249
