Need Help! Changed Spark Plus now...
Old Oct 15, 2009 | 12:40 AM
  #21
JonnyHollywood's Avatar
Well I changed the coil and the wires and cleaned the MAF the best I could. It still won't start. It's like its hesitating to get gas or air. It won't turn over.
Old Oct 16, 2009 | 01:58 PM
  #22
I got my hands on a OBD II and got these codes:
P1141 Load Calculation Cross Check Range/Performance
P0300 Random/Multiple Cylinder Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P1250 Fuel Level Too Low
My fuel is low but it should have enough to start it. I tried to clean off the MAF but it has the weirdest screws in it I have ever seen and I don't have the tool to take it completely off so I just wiped i down in the housing best I could. I put the old air filter in and took the K&N out. I changed the spark plugs to the best out there, NGK Iridium cost me $20 more than what I originally had. It's still not starting. Have a new coil and wires on it too. There was some oil on the electrode of spark plug # 4 but a mechanic I asked said it might have dripped into the cylinder when I first changed it because the threads on the old spark plugs had a good amount of oil on them when I pulled the out but none on the electrode. This is driving me nuts. The car ran fine two weeks ago I do preventive maintenance and it completely dies on me.
Old Oct 16, 2009 | 02:17 PM
  #23
dragonrage's Avatar
I think P1141 is probably either the MAF or MAP sensor. MAF sensor is used to calculate airflow and the MAP sensor senses engine load via pressure in the intake manifold.
I'd say fix the P1141 and your misfires will likely be fixed.
The way to clean a MAF is to spray the wires inside of it down with a safe solvent. I use actual MAF cleaner to do that. Make sure to never touch those wires with anything.
Old Oct 16, 2009 | 02:51 PM
  #24
Midniteoyl's Avatar
You dont need to actually remove the MAF Sensor from the housing to clean it, though its better if you do. If you look at the inlet side of the housing, there is a hole for the air sample and looking at the rear, there is an exit hole. Spray the MAF cleaner into these holes while holding the housing at different angles. It should drip pretty good from both holes.
Not the actual Audi MAF, but you get the idea:
Old Oct 16, 2009 | 07:06 PM
  #25
A_Plus_Remodeling's Avatar
yeah check the maf. I had same problem and i replaced maf and spark plugs and my problem went away. But sounds like your maf just needs to be cleaned. if you bought plugs from napa i would return and go to audi for oem. Single prong.
bigbluebudda
Dec 17, 2010 03:13 AM
lowell513mx
May 3, 2008 01:22 AM
goc305
Apr 27, 2007 07:41 PM
thetryal
Oct 7, 2006 02:42 PM
TheJazz7
Mar 20, 2006 03:34 AM
