Need Help! Identified Problem but Don't Know How to FIX!
Old Dec 5, 2010 | 11:57 AM
je-2.8's Avatar
Default Need Help! Identified Problem but Don't Know How to FIX!
Hello,
My b5 2.8 has always had a slow leak, but last week the leak got so bad that the car won’t even hold coolant, it just dumps out instantly.
So, I did some reading online and since I saw coolant dripping down the bell housing I read that it can be the aux water pump because they are known to be a weak point. Yesterday, I started to take the intake manifold off as if I was going to replace the aux water pump. However, after removing the intake I saw that coolant was pooling up in the valley of my block. After drying everything up and re-simulating the leak I saw that it was coming from this metal line going into the block. (see pictures below) Although it looked like this line was about to fall off, so I gave it a jiggle and low and behold… It fell off!!
So, my question is: What holds this metal line in? It has an o-ring on it but I really doubt that the seal of the o-ring is supposed to solely hold this metal line in. Is my car missing something that holds it in??
Thanks for any help!
Jake
Attached Thumbnails Need Help! Identified Problem but Don't Know How to FIX!-img_5863.jpg   Need Help! Identified Problem but Don't Know How to FIX!-img_5862.jpg
qdoctr
Feb 4, 2014 06:16 PM
morpheous
May 2, 2012 05:45 PM
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
