Need help no idea wtf the problem is
And the CTS is located in the very back of the engine kinda by the fire wall correct? I believe it's green if I remember correctly and I'll try re-gapping the plugs(damn them orilleys :P)
And I'll give this throttle body alignment thing a try. New to me so I'll definitely have to look it up and go from there.
And do you have to change the plugs after you do the sea foam in the vacuum line or oil? Or when you do either or?
Thanks.
Rick
Thanks.
Rick
The CTS is at the back, behind the head, mounted in the coolant crossover pipe. What year is your car? That's going to indicate the color you need. If you plan to change the plugs, wait til after you Seafoam the vacuum - it can foul plugs sometimes. You can regap anytime (sooner the better) but don't put new ones in unless you have done the Seafoam treatment - no sense in risking fouling brand-new plugs.
ok i might do that i just bought one and i think its the wrong one? ill have a picture ill post it with. also just did the vacuum line sea foam. gotta love the smoke :P ill keep you updated on if it runs better and ect.
but here is the CTS
but here is the CTS
