Need help no idea wtf the problem is
Old Nov 30, 2011 | 06:56 PM
Brautty's Avatar
And the CTS is located in the very back of the engine kinda by the fire wall correct? I believe it's green if I remember correctly and I'll try re-gapping the plugs(damn them orilleys :P)
And I'll give this throttle body alignment thing a try. New to me so I'll definitely have to look it up and go from there.
And do you have to change the plugs after you do the sea foam in the vacuum line or oil? Or when you do either or?
Thanks.
Rick
Old Nov 30, 2011 | 07:06 PM
ImTheDevil's Avatar
The CTS is at the back, behind the head, mounted in the coolant crossover pipe. What year is your car? That's going to indicate the color you need. If you plan to change the plugs, wait til after you Seafoam the vacuum - it can foul plugs sometimes. You can regap anytime (sooner the better) but don't put new ones in unless you have done the Seafoam treatment - no sense in risking fouling brand-new plugs.
Old Nov 30, 2011 | 07:44 PM
Brautty's Avatar
It's a 2001 Audi a4 fwd 1.8t. And just re gapped all four right on the spot at .032"
Old Nov 30, 2011 | 07:47 PM
ImTheDevil's Avatar
Ok That means you have the green sensor and need that. Some guys with slightly older cars have blue ones (like me) and replace with the green. You have to use the green.
Old Nov 30, 2011 | 07:53 PM
Brautty's Avatar
Ok and can you pick those up at orilleys? And do they have the o-ring to replace with it? Also is a lot of coolant going to come out when I do replace them?
Old Nov 30, 2011 | 09:48 PM
jonbonesjones's Avatar
Moderator
WAIT i have the green one. paypal me ten bucks ill ship it to you. no **** i ordered the wrong one and it will cost more to return to ecs than i payed for it. i have the clip the o-ring and the sensor.
Old Nov 30, 2011 | 10:19 PM
ImTheDevil's Avatar
^^^ I'd do that. The sensor is about $25 without the clip or o-ring.
Old Nov 30, 2011 | 11:07 PM
  #18
Brautty's Avatar
ok i might do that i just bought one and i think its the wrong one? ill have a picture ill post it with. also just did the vacuum line sea foam. gotta love the smoke :P ill keep you updated on if it runs better and ect.
but here is the CTS
Old Nov 30, 2011 | 11:40 PM
  #19
Brautty's Avatar
And as you explained where its at looks like kind of a pain I can see the old one have no idea how I can't fit in their also a lot of wires in the way
Old Dec 1, 2011 | 08:50 AM
  #20
Moderator
thats the one i have. its a pain to get to. icleaned my throttle body when i did mine so everything was out of the way. its way easier and you get a clean throttle body out of it.
