Need help P1366 code
Old Aug 15, 2012 | 09:12 AM
wenglish's Avatar
Default Need help P1366 code
My 1999 A4 Quattro 1.8T is throwing a P1366 (17774 DTC) code for a cyl. 4 ignition circuit Short circuit to ground.
Anyone have any idea where to start looking to fix this.
I assume in the wiring to the coilpack to cylinder 4 but is there anything else to look for?
Thanks
Old Aug 15, 2012 | 09:22 AM
02A6Beau's Avatar
to trouble shoot this code:
check your fuses
check the wiring to the coilpack
replace the coilpack
do you have any other symptoms (misfires), or just a code? sometimes codes get stored after the problem is resolved. try clearing the code and seeing if it comes back
Old Aug 15, 2012 | 11:26 AM
wenglish's Avatar
Have cleared the code, it takes a couple of days but comes back eventually.
Replaced coil packs 4 months ago.
Figured I would swap the #1 and #4 and see if the code moves first. Then look at the wiring.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
