Need help P1366 code
My 1999 A4 Quattro 1.8T is throwing a P1366 (17774 DTC) code for a cyl. 4 ignition circuit Short circuit to ground.
Anyone have any idea where to start looking to fix this.
I assume in the wiring to the coilpack to cylinder 4 but is there anything else to look for?
Thanks
Thanks
to trouble shoot this code:
check your fuses
check the wiring to the coilpack
replace the coilpack
do you have any other symptoms (misfires), or just a code? sometimes codes get stored after the problem is resolved. try clearing the code and seeing if it comes back
check your fuses
Have cleared the code, it takes a couple of days but comes back eventually.
Replaced coil packs 4 months ago.
Figured I would swap the #1 and #4 and see if the code moves first. Then look at the wiring.
