Need to know what to start looking for.
Here are some recent codes I pulled. Thought someone on here might have been through some of these before and can tell me where I should start. Thanks in advance.
Address 01: Engine
Control Module Part Number: 4B0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 16201
Work Shop Code: WSC 13880
4 Faults Found:
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0135 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0000 1000
Sunday,01,June,2008,22:06:01:10677
VCDS Version: Release 805.0
Data version: 20080529
Address 01: Engine
4 Faults Found:
P1128 - 35-00 - -
you're precat 02 sensor is dead, or you pulled the harness while the engine was running. clear the codes and see if any come back and post them. how does it drive? is your sig photochop? if not, you have like no tire lol
Nah, It's photo chopped lol, but the car is riding fine. This is the third time I pulled the codes. I cleared them today, but I'm sure they will come up again in a few miles. I puttin the order in for the O2 sensor now. It's probably dead like you said. Thanks again.
you're 02 sensor is dead then. get a new one asap as that one hurts your gas mileage the most. autozone might have a bosch universal one where you can splice the wires in. that's wut i did at least. the OE is dumb expensive but it takes a bit longer with the bosch one
Well.....I got the new sensor, installed it and reset the ecu. Drove the car for couple days and I get another cel. Here's what I got now.
Address 01: Engine
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-00 - -
Readiness: 0000 1001
Address 01: Engine
2 Faults Found:
P1296 - 35-00 - -
Vict0ar
Apr 3, 2014 08:38 PM
kinnes042
S4
Apr 10, 2013 06:29 PM
brit.mike13
Oct 17, 2010 08:26 PM
