need pics and advice on 19" hp designs on b5 a4
Old Aug 8, 2009 | 01:02 AM
Tweaked's Avatar
Originally Posted by hiwords
wut offset are they? You should go ask the S4 guys but I think you'll need spacers in the rear. The front might be fine with the size tire you put up. I'm running 235/40 on 18x8 all around with 35mm offset without spacers, lowered on HnR race springs and no rubbing at all. It barely clears everything though. You can take my size and compare it with what you want and see the difference in size. I wouldn't get bigger tires than what I have though.
Hiwords, your tires are too tall, which is why you're so close. You should be running 225/40r18 or 245/35r18 (which is a bit too wide).
Old Aug 8, 2009 | 01:13 AM
hiwords's Avatar
oops lol i posted that from my phone. i meant to say i'm running 225/40 not 235/40. i wouldn't run anything bigger than that.
Old Aug 8, 2009 | 01:41 AM
Midniteoyl's Avatar
Wheels look good though...
Old Aug 8, 2009 | 12:04 PM
a4_2.8tuner's Avatar
i've been running staggered for over 4 years with no issues.
as for tire size, i'd run 235/35 in rear and 225/35 in front.
not sure if you'll need spacers or not. if you do, i can't imagine you'll need anything too aggressive.
Old Aug 8, 2009 | 04:40 PM
Tweaked's Avatar
There's no issues if you don't mind the extra understeer. I guess if he's going for 19"s, it's gonna be a show car anyway.
Old Aug 8, 2009 | 05:16 PM
jsethwerner225's Avatar
Member
thanks for the help!!! any ideas on what the best offset is???? to avoid spacers. i dont take this car to track or anything so will the 19's and staggered be that bad for just everyday driving???
Old Aug 8, 2009 | 05:21 PM
theo2260's Avatar
Member
looks good but definetly not good for the car, one of my golden rules: NEVER stagger a 4-wheel system . . . but hey, go ahead and do you .
Old Aug 10, 2009 | 12:41 AM
  #18
Tweaked's Avatar
Porsche and BMW both offer staggered wheel setups on some of their AWD systems. Granted, it's factory-tuned for it, but it can be done. If you have ESP, there is a possibility the system may prematurely freak out, especially if it sees different wheels speeds due to different rolling diameters.
With a Torsen-diff Quattro setup, the axle with the most resistance (grip) will get more torque and the only EDL is electronically activated, which will not be an issue front to back, but only side to side. With ESP, however, it does complicate the system with more electronics involved which may be negatively affected by staggered wheels or a difference in rolling diameter.
Either way, a staggered setup on a B5 will cause unwanted understeer. If this is a show car, you'll get used to it on the street or might not even feel the difference unless you're driving at the limit.
Old Aug 10, 2009 | 06:50 PM
  #19
theo2260's Avatar
Member
I stand corrected . .
foxracing4500
Mar 22, 2011 01:23 PM
Srbenda
Jan 4, 2011 09:54 AM
jsethwerner225
Aug 12, 2009 07:52 AM
