Need Vag Com Codes to lower just front windows with Keyfob
Old Jul 23, 2010 | 08:13 PM
russcuss36's Avatar
Default Need Vag Com Codes to lower just front windows with Keyfob
I know the code for the all around lower windows is +64. Everything works fine but I can't lower my back left window because the regulator is going out. I just want to be able to lower the front windows instead of all of them with the keyfob. I like that it still closes all the other windows when I hold the lock button. Like the Sunroof and front windows will always need to be closed so if the code doesnt close the back windows thats okay.
Old Jul 23, 2010 | 09:44 PM
Dallas09's Avatar
Ive never heard of any such code, I dont think it really works like that.
Old Jul 23, 2010 | 09:51 PM
ImTheDevil's Avatar
Correct, it's an all-or-nothing setup.
Old Jul 23, 2010 | 10:01 PM
morpheous's Avatar
I've seen a guy with a Audi A4 1.8T close all his windows and sun roof with his keyfob,how in hell can i get mine to do this? can someone tell me everything i need to buy off ebay in order to program my own keyfob?
Old Jul 23, 2010 | 10:20 PM
ImTheDevil's Avatar
Download vagcom from Ross-tech.com (USB 409 version), buy an obd2 to USB cable on eBay, and program it. The procedure is either on audiworld.com or audidiy.com. You can program several features that way. I deleted my horn beep when locking, and set autolock for 15mph, and set it to lock/unlock all doors at once.
Old Jul 23, 2010 | 10:21 PM
02A6Beau's Avatar
I think a4mods has the procedure
Old Jul 23, 2010 | 10:35 PM
morpheous's Avatar
Thank you brudda! could you please post me a link from ebay with the exact obd2 usb cable i need?
Old Jul 24, 2010 | 06:21 AM
russcuss36's Avatar
That stinks that there is no such code. But I got my cable from no one specific. Just looked it up on ebay. Vag Com 409.1 and got that cable for 10bucks and programmed it this morning on the first try. No horn chirp when locked. Lock at 15mph and unlock when key is removed. Close all windows by holding the lock button, open all windows by holding unlock windows (except the sunroof). Unlock all doors on one push. Go to Ross-Tech.com and you can get all the info for the code to have all these features. I love when people look at you like dude the windows and you say dont worry about it. I think its BA but thats just me. Now dont forget that in order to use all of the Ross-Tech/Vag Com software you will need to buy a third party license for 99bucks. But it does some other cool diagnosis things that are included with Vagcom Lite software downloadable from Ross-Tech.com
Old Jul 24, 2010 | 06:28 AM
russcuss36's Avatar
I keep getting a misfire in cylinder 2 when I checked with my vagcom. I have yet to switch the Ignition Coil Packs to see if that follows but I got the new coils from Audi a month ago. I still have not done a compression test, but I know the plugs are gapped right .028 and they are brand new NGK plugs (7bucks a pop). I changed some vacuum lines (which ones unknown). I also changed my fuel filter and I still get the misfire. Anyone have any suggestion, code pops up with intermittent misfire. Took it on a long drive tonight, going to check in the morning if any other codes pop up. I have no battery in my laptop so I have to plug it in somewhere to check the codes. Not so convenient!
Old Jul 24, 2010 | 11:07 AM
morpheous's Avatar
Thank you for the info,there are a lot of them on ebay but they are mostly from hong kong,i normally don't trust buying anything outside the usa,for fear of getting ripped off,also the shipping times are long! how long did your vag-com take to reach your front door? there are sellers in the usa,hand full but they charge 25-35.00 each for a vag-com,so its a trade off,closer=more money,farther=less money but longer wait time.
