New 98 A4 Quattro: Couple things need fixing
Old Feb 20, 2012 | 06:32 PM
  #21
jonbonesjones's Avatar
Moderator
how do you have the "adaptor" made. i want a taller cylinder style shifter, not along as yours tho.
Old Feb 20, 2012 | 07:20 PM
  #22
Falcon Punch's Avatar
I basically drilled out the bottom of the **** to be a little smaller diameter than the shifter threads, then cranked it down. That's why the copper collar was necessary. As I was cranking down, I could feel the wood separating to accommodate the shifter.
If you wanted to do something a little more rigid, Home Depot sells female threaded couplers that you could press into the bottom of... well... pretty much anything. Just make sure that the metal is taking the brunt of the shifting force, otherwise whatever's wrapped around it is liable to crack over time.
Here's how I would do it, assuming I could find everything that's the same thread pitch.
Attached Thumbnails New 98 A4 Quattro: Couple things need fixing-untitled-1.jpg
Old Feb 20, 2012 | 07:22 PM
  #23
Moderator
do you know the specs of the shifter threads? i have some neat **** laying around id like to make a shifter out of
Old Feb 20, 2012 | 08:17 PM
  #24
Looks like 12mmX1.5.
Might need to go to Ace Hardware or some specialty hardware store to get everything you need. Home Depot tends to have mostly English standard sizes. Lowes might have it.
Old Feb 20, 2012 | 10:24 PM
  #25
Moderator
Thanks for searching for me Im gonna go snag something tomorrow theres a fastener store around the corner.
Old Feb 25, 2012 | 06:23 PM
  #26
Guess who has 2 thumbs and is a very unhappy camper?
This guy.
Apparently the CV's that the previous owner bought are not the right ones. The spline shafts on the wheel side of the new axles are at least 10% smaller than the ones that came off the car. Of course we didn't find that out until, you guessed it, we're elbow deep in axle grease and have the whole thing pulled apart.
Furthermore, the case bolt that's hiding behind the transmission mount is impossible to get to unless you have a long type torx bit. Which I don't. Fun.
In the end, we spent 2-3 hours and ~$140 on fluids and time on the lift to do... uh... nothing.
On the lighter side, it's just a matter of buying the new parts and getting back to it. All the bolts are broken now, and I know what I'm doing, so it'll go a lot faster next time. Royal Purple motor and transmission oil change, so MOAR POWAH!
ilovelagar
Mar 18, 2013 07:58 PM
Oldschooltuner
Sep 20, 2011 11:47 AM
DankesterA4
Sep 28, 2009 07:58 AM
rplets15
Jan 30, 2009 12:39 AM
Dunzie182
Sep 2, 2006 05:44 PM
