New to Audi fourms wheel bearing
Old Jul 3, 2011 | 12:43 AM
Donman19's Avatar
Default New to Audi fourms wheel bearing
I am trying to figure out what a roaring sound is. It sounds like i am running mud terrains on my b5.5 A4. Noise goes up with speed and stops when going left. Rotated tires which i thought was the problem since i have cheap federals but still the same. Is this the wheel bearing?
Old Jul 3, 2011 | 03:38 AM
DOC_DEPALMA's Avatar
Sounds like it to me. Easy to do yourself
Old Jul 3, 2011 | 08:20 AM
ImTheDevil's Avatar
Yup wheel bearing on left side is shot.
Old Jul 4, 2011 | 03:27 AM
Donman19's Avatar
It's hard to figure out what side it is i am leaning toward the passenger side bearing. It roars when i turn right or go straight but stops around left turns.
Old Jul 4, 2011 | 06:23 AM
ImTheDevil's Avatar
It's the left side.
Old Jul 4, 2011 | 10:04 AM
Mad Cow's Avatar
You should replace both though, last time I replaced 1 bearing the other one started making noise a week after.
Old Jul 4, 2011 | 06:30 PM
dnoble37's Avatar
i dont know what side, but id agree at least one of the bearings are bad. i had a similar problem not long ago. it went bad at the same time i got new tires, so i blamed the tires at first. i waited for the tires to wear for a about a week then realized something else had to be wrong.
Old Jul 4, 2011 | 07:26 PM
audinoob88's Avatar
New to audi's too. My rear wheel bearing is loose and Im wondering if they like every other bearing where I can just tighten it up or is it a press in bearing
Old Jul 5, 2011 | 03:45 AM
Donman19's Avatar
Ok thanks ordered one from Mjmautohaus hopefully i get it in soon and get this changed! I'll try the left side.
Old Jul 8, 2011 | 04:13 AM
Cristisor's Avatar
You can tighten up the bearing but don't do it yourself because I replaced a bearing that was installed 1 month before because the mechanic didn't do it job properly.
