New Forge K007 DV... No sound at all
yeah.... now it makes sense....the piston faces the turbo!
so the air coming from the turbo pushes the piston against the spring...( damn loading a cape size ship and unloading it is way more simple!
we say the same thing all over again and again! hahaha)
thanks a lot guys! Tomorrow I will check it out!
we say the same thing all over again and again! hahaha)thanks a lot guys! Tomorrow I will check it out!
well that's my stock one.... I put it back.... turn the 007 back.... switch it with the splitter one
(I wanna say that I am happy that I can hear my stock one do the blow off
thats exactly how I put my 007 and there was no sound from it at all. I am not going to hide back that I still dont get it how it works if you put it backwards... so the piston faces the airbox....
)thats exactly how I put my 007 and there was no sound from it at all. I am not going to hide back that I still dont get it how it works if you put it backwards... so the piston faces the airbox....
oh god...now I get it...clearly.... yeah thanks a lot for that
.... you put up pressure...the small hose put pressure down so the turbo doesnt lose pressure.... when you let your foot of your gas..the small hose sucks the piston....the air gets in the DV...and heads towards the airbox. Got it
thanks a lot Drifter
I will get back in 2 days to update how the splitter works.
(thank you both for your time...)
and another question.... should I do this mod as well? if I get the Forge Splitter thing??
Re-Hash on the N249 Valve
not sure if mine has it..its 99.5!
Some people do this mod to delete bad or misbehaving n249 valves, others delete it just to simplify the vacuum system. Mine works just fine, so I'll leave it there until it doesn't. The way to tell if you have this would be to look at your intake manifold. The n249 is underneath the runner to cyl. #3 and will have a vac line running from the IM to the n249, then from the n249 to the DV
Okay I got the thing installed.... did 16 clicks as the instructions said.... anyway even at 2000 RPM with 2nd...if I let off my foot I can hear my blow off valve...is that normal??? I mean it doesnt sound like it does at 4000 RPM..but still....
