New owner with turbo question
Old May 12, 2011 | 02:29 PM
KBHumphrey's Avatar
Default New owner with turbo question
Greetings all.
I'm 12 days into my 98.5 AEB 5spd w/146k. Coming from the E34 BMW platform, it's quite a bit different, neither better nor worse, just...different.
Anyway, I have a question about the turbos in these things. I've searched through a bunch of threads but the specific info didn't really bubble up.
Is it possible for the turbo to be completely dead and yet the engine shows no signs? I don't have any squealing, dentist drill sounds or other unusual nosies. If it's still operational then it's the weakest turbo I've ever run across. I can't feel any kind of boost passing 2500rpm at all.
There's no boost gauge in the car so I can't track it that way. Is there another method to tell?
Old May 12, 2011 | 04:47 PM
McGovs2.7TB5's Avatar
You can use VAG-Com to log requested boost vs actual. The turbo isn't big at all but you should definitely be able to tell when its fully spooled up. You probably have a massive boost leak as i would think you'd be able to tell the turbo had **** the bed(noise, smoke etc.)
Where are you located? I'm sure someone near you has VAG-Com and would help you out. The guys on here are really cool.
Old May 12, 2011 | 07:34 PM
KBHumphrey's Avatar
Yeah, I figured I would be able to hear or see something if the turbo had died. The car idles and accelerates just like I would expect, just lacking any punch even from a small turbo.
I'm in SE WI so if there are any brothers/sisters in Milw or Far North Chicago suburbs willing to lend out a Vag, I'd mucho appreciative...
Old May 13, 2011 | 10:19 AM
FASTER's Avatar
Tech Slut
Not with his narrowband ecu.
AudiJax2015
Jan 11, 2015 09:01 PM
mochsl99
Oct 30, 2010 11:34 PM
Jonas McFeely
Apr 23, 2010 03:40 PM
alticjob
Mar 30, 2008 02:48 AM
Auditurborach
Nov 19, 2007 06:08 PM
