Newbies first limpmode
Old Feb 16, 2011 | 04:21 PM
lolo22's Avatar
Default Newbies first limpmode
Great I think im in limp mode now. Car is only pushing 5 psi on a apr chipped ecu. I was playing around with the cruise control while driving it but i didnt order any programs with the chip. My cel has been on for 3 days now because of a bad o2 sensor, would that have any effect with it.
Old Feb 16, 2011 | 04:41 PM
lolo22's Avatar
Thank you jesus. I just ran out and disconnected the battery for 15 mins plugged it back in, then let the car read the ecu for a couple minutes then I had my boost back. Now that I dont need help with the limp mode any ideas why it was fixed by just unplugging the battery.
Old Feb 16, 2011 | 04:53 PM
JoBuNY's Avatar
When you unplug the battery or ECU and turn the car back on it resets the fueling I believe. I know when I had my A4, when I swapped in the Chipped ECU I had to plug the battery back in, turn the key forward for a couple minutes and you would hear it adjusting. When it was done adjusting you could start the car and good to go. Did the same thing when I took the Chipped ECU out, had to let it adjust again.
If it keeps doing it you could be throwing codes and not seeing a CEL - you should get VAG COM and scan it to make sure you have no codes in there if the problem happens again
Old Feb 16, 2011 | 05:03 PM
nzant008's Avatar
After disconnecting the battery in your cars you need to get your garage or if you are luck enough to have a VAG reader (which can also reset codes, throttle etc), to do a Throttle Adaptation. This resets your computer so that it knows the zero mark. If you dont you might find that when you depress the throttle, there is a momentary delay in engine response. Should only take 5 minutes.
Old Feb 16, 2011 | 10:18 PM
ImTheDevil's Avatar
Originally Posted by JoBuNY
When you...
Holy crap John, I can't believe you even remember your login for this site=)
Old Feb 17, 2011 | 08:36 AM
JoBuNY's Avatar
Turning the car forward to the accessory position does the throttle adaption - that's the name I couldn't think of yesterday when I put up that post. I did it multiple times with my A4 when swapping ECUs or Batteries and it worked every time.
LOL I had it remember my password :-P
Old Feb 17, 2011 | 10:42 AM
Mike-2ptzero's Avatar
Correct. On the ndbw cars there wont be any noise, only on the dbw cars you will hear the ecu doing a few cycles of the throttle body from closed to WOT.
If it is a bad pre-cat 02 sensor the car might go into limp again. If it is that 02 you need to put a new one in.
MKE_Audi
Jan 6, 2011 08:16 PM
boostedB6
Jan 8, 2008 07:21 PM
Blue_S4
Nov 11, 2007 11:06 PM
A4...kyle...08
Aug 19, 2007 05:03 AM
