no power for heater + fog lights!!!!
Old Nov 20, 2008 | 08:27 PM
divineaudi's Avatar
Default no power for heater + fog lights!!!!
hello everyone !!
well this is what happened i tried to change my radio which failed miserably. after 3 days the power to the heater failed. there was no power to turn the heat on or the fog lights!!! i hope its something very simple!! does anyone know if thats a fuse or something else??? thanks in advance
Old Nov 20, 2008 | 08:33 PM
sineo's Avatar
Well, you could go ahead and check your fuses for a bad one. The box is behind a panel to the left of the steering wheel. Open your door and pry off the cover. Check fuses 3, 5, 25, and 36.
Old Nov 20, 2008 | 09:18 PM
divineaudi's Avatar
Thanks omg i love you i just fixed it !!!!!! that means i dont have to go to a mechanic !!!!!
Old Nov 20, 2008 | 09:30 PM
B5 owns's Avatar
Fuses usually go for a reason, so if it blows again, you are going to have to figure out why
Old May 21, 2010 | 10:29 AM
mjbutera's Avatar
Default Blows fuses....
I checked fuses 3, 5, 25, & 36...
The fuse that keeps blowing on mine is #5 (
I replaced it and it immediately blows back out within 2 seconds of starting the car.
This really sucked because I was driving home to Pittsburgh yesterday evening and this morning from Louisiana. I was in a downpour for 6 hours straight but about midway the climate control, radio, & fog lights stopped working. Kinda hard to drive without defrosters when you already can't see the car in front of you with your wipers on full blast.
Any suggestions as to why it keeps blowing? I replaced my factory radio for an aftermarket head unit, sub woofer, & hard wired GPS into the radio wiring harness...but that has been working fine since November. Maybe I ran the radio & climate control for too many hours nonstop? idk
Old May 21, 2010 | 11:41 AM
chocalotstarfish's Avatar
Super Moderator
Clearly if it keeps blowing there is a short somewhere! Replacing the fuse isn't going to do anything! Go back and recheck the wires make sure nothing is touching!
Old Jun 5, 2010 | 01:09 PM
mjbutera's Avatar
I had a guy take a look at the wiring....a really good experienced ASE Master Tech... couldn't find anything but thinks he got close and by moving around some wires, caused the short to go away! He never actually was able to locate it and since the car won't act up anymore, won't be able to find where it was unless it shorts again. Silly gremlins
Old Jun 10, 2010 | 08:20 PM
Rowe's Avatar
First of all, thanks for this post. I had already checked fuses 25 & 26 with nothing abnormal but after reading this I looked at fuse #5 and it was blown. I replaced it with another 10 amp and like above, it blew within 2 seconds, so I went ahead and tried a 15 amp fuse (which I realize most people wouldn't recoment or try) but believe it or not the radio turned on and so did the climate control/ac fan. Heres the weird part, as this was happening I could smell electrical smoke and saw it coming from the hood near the drivers headlight. I turned off the key right away opened the hood and it looks like the smoke was coming from the wiring I soldered into place when my oil temperature sensor ripped out. I removed the wire from its clip on the water pump and pulled it back then started the car and the climate control, fan, and radio all work great and no smoke.. I'm going to pull my car into the garage now and re-insulate my oil temp wiring and hopefully thats the end of it. My symptoms of the origional problem were no heat or a/c, no climate control system power, no radio initially but soon noticed that it still worked but wouldn't turn off when I removed the key. Good luck
Old Jun 10, 2010 | 09:54 PM
Rowe's Avatar
Expanding upon my previous post, I just got done removing the connection for my oil temperature sensor on the bottom of the oil pan. It was the cause of my radio/climate control problem and was melted internally. It looks like the #5 fuse, climate control, blower fan, and radio are all related. Apparently the sensor itself shorted out and was the cause of my smoke and blown fuses. Good luck and hope this helps someone out..
Old Dec 7, 2010 | 09:58 PM
mjbutera's Avatar
Wow...even though my problem hasn't recurred since my last post, my oil sensor and wiring was all corroded and not functioning. Just had it replaced. Was it all related? We can only speculate..I hate intermittent problems because there is no absolute certainty that the oil sensor was the root of the problem.
Anyway, thanks to everyone for the posts. until next time....
thuucdavis
Apr 30, 2014 05:21 PM
Town573
Jan 28, 2014 05:40 PM
BeemerK12S
Jan 12, 2014 08:21 AM
A4Cragman
Dec 3, 2010 05:56 PM
ollyj
Oct 14, 2010 02:09 PM
