no spark companion cylinder then no start
Old Nov 7, 2013 | 03:04 PM
rshepler217's Avatar
Default no spark companion cylinder then no start
a couple days ago I started to have a misfire on my 96 2.8 12v. I pulled the plug wires off the coil and the companion cylinders for 2 & 4 both had no spark so that led me to believe that the coil was bad. I bought a new coil pack and am still waiting for the part to arrive however the car has no spark anymore at any cylinders. could I be looking at an ignition control module now as well or is it possible that the other 2 coils just happened to go bad shortly after? all wires and connectors are in good condition and an oscilloscope shows the computer is getting inputs and sending output signals. has anyone had anything similar to this happen?
Old Nov 7, 2013 | 03:36 PM
redline380's Avatar
Legal Moderator
yup, ignition control module. most likely bad
Old Nov 7, 2013 | 04:11 PM
I just went to check the codes to see if there was anything else new after cranking it for a bit and now it wont even connect the the computer. I also don't believe I hear the fuel pump turning on. now im leaning towards ignition switch.
Old Nov 7, 2013 | 04:39 PM
yep, no fuel going to the engine either.
Old Nov 7, 2013 | 05:25 PM
ok so I was looking at the icm and before it was a small box that the previous owner had installed with a dial for min-max. when I read the back, it said performance chip. took that "performance" chip out and rewired everything correctly and car started right up. something must have failed in the potentiometer part of that chip causing no signal on a part of the circuit. damn ebay performance parts. still no spark on cylinder 2 & 4 so a new coil will replace that one.
sonsa4
Feb 13, 2012 12:09 PM
heywood08
Jul 9, 2011 01:34 AM
Sidewayzracer
May 15, 2009 10:47 AM
auditurbo381
Mar 22, 2008 06:01 PM
A4 the Quattro
Apr 27, 2006 04:35 PM
