no spark in cylinders 1 and 4
sounds good to me but were is the icm ignition control module located on the car.its a adr engine code and uses a bosch coil pack
Thats true, if this is a 2.8L then your problem isn't the ICM. On the 2.8L you have one coil pack fire two cylinders. If the coil pack is firing 1 and 4 then swap the coil set and see if the misfires move.
