Noob needs help
ORIGINAL: InfamousA4
I just picked up a 97 A4, bone stock until we put a boost control on it. Now at about 10 PSI, it's cuttin the fuel...whats the best way to fix this problem? Thanks
https://www.audiforums.com/m_700266/tm.htm
you can't just throw a boost controller on your car and turn it up, "saftely" ask jeff about that.... i think he ran 14 psi and blew his turbo
chip it first or over boosting your turbo will blow it in a very short time.
then be careful if you use a boost controller, manual boost controllers can be tricky and come back and bite you in the a*s if you abuse it even if you chip your a4
