Normal boost? <Video included>
Old Jul 5, 2012 | 02:47 AM
DanaB6's Avatar
Default Normal boost? <Video included>
Im hitting about 20 psi when i go full throttle and the boost pretty much starts going back down to 10 from there, if you watch the video i hit 20 psi, and when i shift again i hit 20 again and the 2nd time it loses boost pretty quick, happens every time. Is this normal or some sort of boost leak? Normally if i go up to 5000-6000 rpm itll be down to 10psi. And yes my DV is upgraded to the 710n.
http://www.youtube.com/watch?v=hV5gx...ature=youtu.be
Old Jul 5, 2012 | 03:18 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Yep, looks normal enough to me.
Boost really starts to drop off past 5k rpm on the K03. No real point shifting later than 5500.
Old Jul 5, 2012 | 07:53 AM
CCA4's Avatar
Couldn't hurt to check for leaks but that seems pretty normal to me. What tune are you running?
Old Jul 5, 2012 | 02:22 PM
Sheasta's Avatar
Ko3 wont hold boost til redline. Like he said shift 5-5500 rpms.
Old Jul 5, 2012 | 02:52 PM
DanaB6's Avatar
I have a ko3s if that makes a big difference, but its just weird how it spikes 20 and literally jumps down to 15 then slowly starts losing boost after 15. And i have this tune UPsolute.com The Chiptuning Company
its just odd im reading peoples posts and their diffrent stage 1 tunes hold 17 psi.
Old Jul 5, 2012 | 02:55 PM
All the tunes behave a little differently, it's all in how they are programmed.
I never hit 20psi with my tune. I peak at 18 and hold around 15-16 until it starts to taper off.
jputek1
B7 Models
Nov 3, 2013 12:28 PM
Anthony TheSire McGuire
Feb 1, 2013 10:00 PM
AlyAudi03
Oct 13, 2012 11:11 PM
audinoob27
Apr 2, 2012 06:32 PM
bottlecap
Mar 27, 2009 02:20 PM
