obd 2 not connecting
Old Dec 25, 2017 | 02:59 PM
  #21
Arthur__kh's Avatar
Default Reconnect the fuse for diagnostics helped
Thanks to who mentioned this but it helped me connect the scanner as well. Take out the diagnostics fuse and connect it back in after a few seconds. After that my scanner connected to the ECU.
P.s.: first contribution in these forums, yay me. Or any forum for that matter. Looking forward to the adventure with my new B5.
Old May 7, 2019 | 09:32 AM
  #22
neil-boo's Avatar
Default Check TCM
Originally Posted by joe99a4
My check engine light is on. i tried to get the code with an obd2 scanner but it wasnt able to connect with the car. i have no idea where to go from here. Any help would be appreciated.
Check if your transmission ECU got wet cuz mine did and caused a short at K-Line. No check engine, no codes, no driving issues, but box was wet😩.
Old Dec 28, 2020 | 11:52 PM
  #23
PriceIsWong's Avatar
Originally Posted by Tweaked
Is the factory radio installed?
What scanner do you have?
I have a factory radio and the OBD2 Bluetooth connection scanner and it says failed to initialize scanner.
Old Dec 28, 2020 | 11:54 PM
  #24
Old Apr 29, 2021 | 12:57 PM
  #25
Sean Brown's Avatar
Originally Posted by acwebster
Why do you ask about the ABS light? I have a 98 A4 and I have taken it to 3 different smog stations and none of them could get OBD II communication. My ABS light is on.
I know this thread is old I'm having the same issue I have power to my OBD Port does not communicate and my ABS light is on what was your remedy
Old Apr 30, 2021 | 02:56 AM
  #26
Cybersombosis's Avatar
Try unplugging your ABS module and scanning again. A bad ABS module or an aftermarket stereo will sometimes stop the car from communicating.
Old May 5, 2021 | 01:32 AM
  #27
Looknohands9121's Avatar
Default Hate to keep this thread going....
I’m having issues getting my 2001 A6 Quattro inspected through NYS I can get it connected through vag-com after resting the system but once the car is running it looses connection to k-line system. I checked voltage too #7 port on the obd11 and ignition on car off it’s 5.7 volts engine on I’m at 12.4 at #7 pin! I have and aftermarket radio I followed Ross-techs page and cut the k-line from the harness I checked voltage there and it’s 12.4 as well. Does anyone know where the k-lines all come together in C5-A6? I don’t have any lights on other then a brake pad light. I’m kinda lost at this point any help would be greatly appreciated! I need to get my car inspected ASAP.
Old Nov 14, 2022 | 03:54 PM
  #28
Sammy1992's Avatar
Default Obd2 port not working
Hi I have an Audi a3 2.0l Tdi and I have an engine light and an air bag light on and when I try to connect it nothing seems to happen it won’t connect to the car. When I do 80mph I lost all power any help please. Many thanks
Old Apr 4, 2023 | 03:11 PM
  #29
usama's Avatar
Default I have the same problem can you help
Originally Posted by ghost6303
also is your ABS light on?
i have the same problem
and i have a abs and anti slipping light on in my dashboard !?
Old Apr 6, 2023 | 11:17 AM
  #30
Did you try disconnecting your ABS module and trying again?
