odd Rpm problem
Old Aug 8, 2008 | 02:48 AM
Lanc5690's Avatar
Angry odd Rpm problem
ok so this is very odd, the rpm bar when it gets past about 3k rpm's will jump a few hundred rpms then come back down and continue doing this, its like its "fluttering" now it cant be a shifting issue because im staying at a constant speed and the higher i get the rpm's the more it flutters, also...
on a side note ive noticed the car gets a loud "hum" at higher speeds, new tires, it isnt bumpy so shouldnt need balanced..exhaust issue???
Old Aug 10, 2008 | 11:56 PM
ImTheDevil's Avatar
The hum, if it's getting louder as speed increases, could well be a wheel bearing problem - these cars are known for it. See if you get more or less noise when cornering at speed. If the noise gets louder, for example, when you turn right, and gets quieter when going left, then it's likely a left-side bearing going south (turning right loads the left side of the car's suspension, and makes more noise - going left unloads it and lessens the stress on the bearing).
As for the revs, I agree - that is weird. Wish I knew what to tell you on that one, unless you're getting some random clutch slippage that doesn't manifest at the torque levels produced at lower RPM.
Old Aug 11, 2008 | 12:11 AM
hiwords's Avatar
does it jump when you're car is in neutral?
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
