Oil change question
Old Dec 29, 2010 | 10:17 PM
A4 2000's Avatar
Originally Posted by dragonrage
Better than M1 5w30 but 5w30 is not an ideal oil weight. The 0w30 is really closer to 0w40 which is good.
40 is better than 30 since it resists heat better. You should notice the oil temp run a little lower with a 40 weight which is better for the engine. In the manual it even says that the engine had a a high quality 40 weight (probably meaning a fully synthetic oil) put in from the factory, but if you can't acquire it, then 30 can be used.
Old Dec 29, 2010 | 10:46 PM
dragonrage's Avatar
Originally Posted by A4 2000
I agree with everything you said except for the Pennzoil part. Honestly I heard that Pennzoil is garbage. I would use Mobil1 any day over that. It's like putting Arco in your gas tank.
Pennzoil Platinum and Ultra are amazing. Both are better than M1. www.bobistheoilguy.com
The only dino oil I'd consider is Castrol GTX. There were a couple of well-known but bad brands of dino oil that would have wax separate out and get all of your engine. I think Pennzoil was one years ago.
Old Dec 30, 2010 | 01:55 AM
y^0's Avatar
y^0
man, i never knew this was so serious unless you were into racing your a4. i just put the stuff in and let her go.
Old Dec 30, 2010 | 08:41 AM
dragonrage's Avatar
It's much more important in any car with a turbo. And the 1.8 is known to have oil sludge issues which also makes it important.
Old Dec 31, 2010 | 12:21 AM
A4 2000's Avatar
Yep. The amount of heat that's produced with a turbo is the reason why using a good quality oil is so important. Most conventional oils or thinner oils are more likely to break down quickly under high heat. Oil turns into sludge when this happens.
Old Dec 31, 2010 | 08:51 AM
CCA4's Avatar
I change mine every 3k with Mobil1 0w-40 euro formula and Mobil 1's big *** filter, no exceptions. It's a bit more expensive but I've had good experience with it so it stays. I've never used anything else in either of my A4's, so I can't comment on that.
Old Dec 31, 2010 | 09:48 AM
czum09's Avatar
Oil is on sale here at O'Rileys its 4.99 a quart for mobil one 0w-40!!! I might buy like 3 cases haha ^and im with CCA4 I'd do it every 3k no exceptions. Thats what i do and I have no issues. I def would not use 5w-30.
Old Dec 31, 2010 | 09:51 AM
  #18
CCA4's Avatar
Seriously!? That oil is $10/qt. in DC
Old Dec 31, 2010 | 11:22 AM
  #19
bradtyler02's Avatar
Anyone else get the letter in the mail about refunding money already spent to repair any damages caused by sludge?
Old Dec 31, 2010 | 12:10 PM
  #20
01ofew's Avatar
O.P. Mobil One oil isn't "real" synthetic oil,its a synthetic "blend"= crap.Stick with the Mfg'rs. recommended oil, Full Synthetic 5-W40.Good synthetic oil will have NO problem lasting 5000 miles.The 3000 mile oil change "myth" netted the BIG oil companies OVER 2.5 Billion (yes billion) dollars in 2009 alone!!. $.02
