Oil pressure problem: Dealer has no idea!
Call shokan and see what a used one will run you. You don't NEED a new engine, these engines will last forever as long as you take care of it. I would remove the new oil pump and pick up tube on your engine, but a used one, slap the parts on and call it a day. There is a VERY LOW chance a used engine will be bad. I've seen these motors with more than 500,000 on the clock.......probably their 3rd turbo but thats besides the point.
I was looking on ebay and the average price, lowest miles I could find was 80k, is about $1500. I will give Shokan a call. Who knows, maybe the oil cooler replacement will fix it though. Gosh that would be nice.
Heres a description of your oiling system and some troubleshooting, testing procedures to try:
http://eva2.homeip.net/Bentley99-05/...n%20System.pdf
I am going to try replacing the oil cooler first, then shoot some seafoam in my vacuum lines because a local Audi club guy swears that will fix it. And then update next week when I'm done. Who knows what will happen after that.
BTW, there are two thrust bearing inserts that are on either side of the #3 main bearing cap. they are not part of the bearing itself but are inserted next to the main bearing and they look like two U shaped peices of metal with a short tab on the bottom facing into the oil pan, these are what keep the crank from moving forward and back in the bearing saddles.
The seafoam in the vacuum lines won't do anything for the low oil pressure. It needs to go directly into the the crankcase, through the oil filler opening in the valve cover.
Shortly I too will be pulling the oil pan and replacing the oil pump and pick-up tube. I'll look at the rod and main bearings too while I am in there and replace them if I need to.
