Oil pressure problem: Dealer has no idea!
Subscribe
Mar 12, 2011 | 09:08 PM
  #61
Quote: The seafoam in the vacuum lines won't do anything for the low oil pressure. It needs to go directly into the the crankcase, through the oil filler opening in the valve cover.
I seafoamed my engine numerous times. But my problem is not oil sludge in the engine. So now I am taking any suggestions I can get. There could be a clog somewhere in my vacuum lines or breather system that can be cleared out. It's a long shot but it is easy and cheap.
Reply
Mar 16, 2011 | 02:58 PM
  #62
Replacing the oil cooler today. My haynes manual doesn't mention it at all. I found this DIY write up. Very good one.
http://www.audizine.com/forum/showth...Oil-Cooler-DIY
Reply
Mar 16, 2011 | 04:48 PM
  #63
Well, just replaced my oil cooler. The old one was pretty disgusting and deteriorating. And I had a leak because it was pretty loose. Surprised I never noticed that while changing my oil filter. Anyways, it didn't work. The oil pressure light came on anyways. I'm going to manually check it again just to be sure.
Reply
Subscribe
