oil problem
Old Apr 8, 2010 | 04:50 PM
dub 687's Avatar
Default oil problem
i have a 96 a4 12v, the oil light is coming on and it is leaking quite a bit of oil so i replaced the oil pan gasket as a starter hoping it just had to do with oil level, but thats not the case the oil level is perfect and the light is still coming on so i has to be something with the pressure. does anyone know of and possible quick fixes or do i need a new oil pump?
thanks for any input
Old Apr 8, 2010 | 05:06 PM
Dallas09's Avatar
Could be the oil pressure switch thats faulty. You need to hook it up to a mechanical pressure gauge to find out. Could be a plugged pickup line, but since you have a 12v i doubht it.
Old Apr 8, 2010 | 06:46 PM
dragonrage's Avatar
uhh... if it's leaking oil then that's what you need to fix first...
Old Apr 8, 2010 | 07:19 PM
euroimport88's Avatar
mine was the same way i replaced the oil pressure switch and the light never came on again
Old Apr 9, 2010 | 12:58 AM
dub 687's Avatar
thanks ill start with the oil pressure switch, and i know i need to fix the oil leak, i just did the gasket yesterday so im trying to find the new leak still, looks like its coming from above the oil pan on the drivers side, but the valve covers and everything are clean, just gotta do some cleaning then waiting.
Old Apr 9, 2010 | 01:01 AM
Dallas09's Avatar
could be the oil cooler its attached to the oil filter
Old Apr 9, 2010 | 07:21 PM
dub 687's Avatar
do you have to take the front clip off and put it in the "servivce position" to do this, or can you reach it from under the car?
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
