Oil temp low?
Old Oct 13, 2012 | 05:51 PM
  #41
Pbcrazy's Avatar
Will do! My car sounds like a tdi right know :/
Old Oct 14, 2012 | 10:31 AM
  #42
Pbcrazy's Avatar
Ok so I went to my local autozone and got a thermostat, replaced it, and bled the cooling system but when I was bleeding it, I let it idle till normal coolant temp and the oil temp gauge is still where it was before I bled it. I'm going to drive it and later and update you guys if it goes up like it should
Old Oct 14, 2012 | 10:34 AM
  #43
jonbonesjones's Avatar
Moderator
whats your oil level? did you scan it while you were there to see if theres any stored codes ?
Old Oct 14, 2012 | 10:51 AM
  #44
Pbcrazy's Avatar
Oil level is at the max line, ill scan it after I drive it
Old Oct 14, 2012 | 03:51 PM
  #45
Pbcrazy's Avatar
Drove it, no codes, oil temp rose very slowing and got just above where it was before I replaced it. I would like to say though that I only drive for about 10 minutes or less. Very rarely do I drive for more than that
Old Oct 14, 2012 | 07:13 PM
  #46
Moderator
Driving ten minutes at a time is really bad for your car. I wonder if using prestone has anything to do with it.
Old Oct 14, 2012 | 08:04 PM
  #47
redline380's Avatar
Legal Moderator
i wouldnt say driving ten minutes at a time is bad, it depends on how you drive. but i will ask you to drive around for an hour, some hard driving and some slow driving and report back with your temps
Old Oct 14, 2012 | 10:26 PM
  #48
Moderator
I'd say driving ten miles an hour is bad in the long run. Fluids never get to temp, car never gets really running. Like flicking an on off switch a million times repetedly, it's going to die a lot quicker.
Old Oct 15, 2012 | 06:50 AM
  #49
Pbcrazy's Avatar
I live in a city/town environment so I drive to school and back (8 minutes) and work and back (10 minutes), Both times i drive on averge about 45 mph. Ill go out with some friends on a fun drive and see if everything gets up to temp
Old Oct 15, 2012 | 05:18 PM
  #50
Pbcrazy's Avatar
Ok so I drove 30 minutes (10 minutes at a time, 25 minute break in between) today and it got up to about 200 degrees. With stopping every 10 minutes I would say that is definite improvement
