Orange fluid leak
Old Jul 9, 2010 | 08:43 PM
Seanu30's Avatar
Default Orange fluid leak
Believe i have a leak coming from the passenger side with orange fluid. What type of fluid/ where could the source possibly be?
Old Jul 9, 2010 | 09:19 PM
jjcrt2's Avatar
it would help if you stated the year and engine of your car...........................and im pretttttty sure theres no orange fluid in any of our cars maybe someone spilled orange juice haha
Old Jul 9, 2010 | 09:46 PM
brett83's Avatar
Member
could it be coolant from the heater core?
Old Jul 10, 2010 | 02:41 AM
Seanu30's Avatar
99 a4 1.8 and i think it may be a possibility from the coolant.
Old Jul 10, 2010 | 07:44 AM
chocalotstarfish's Avatar
Super Moderator
If it's orange and it's coolant... You have bigger issue than the leak What color is your washer fluid? And you would know just by smelling it if it were coolant.
Old Jul 10, 2010 | 08:35 AM
Seanu30's Avatar
washer fluid is blue, did a scan and code p1136 came up. came up reading that i was running rich/lean. possible idea of a bad injector/ mafs
Old Jul 10, 2010 | 08:47 AM
Seanu30's Avatar
car is also running a bit sluggish making a strange noise?? not sure where from exactly
Old Jul 10, 2010 | 09:23 AM
Seanu30's Avatar
found one loose hose, reconnected that and took it out. The noise im hearing is a ticking/grinding noise. Car is running fine, but when i run low rpm and hit the breaks i hear the grinding noise
Old Jul 10, 2010 | 02:11 PM
Tourbo24's Avatar
is your coolant level going down? if yes then it is the water pump that is leaking and making this grinding/ticking noise
Greg23
Apr 16, 2014 04:09 PM
etyrol
Aug 26, 2013 10:24 PM
vtraudt
Feb 25, 2012 11:09 AM
thecollegestudent
May 10, 2009 09:51 AM
meta4
Sep 26, 2006 09:34 PM
