overhead courtesy light - need help
Old Jul 22, 2009 | 11:41 AM
hypermoto's Avatar
Default overhead courtesy light - need help
Tried changing the overhead courtesy light above the driver side sunpanel, as it is not working. I finally pulled hard enough and got the darn plastic assembly to pop-out. I changed the bulb, which didn't help.
Now on the left side, opposite of the electic plug in, the metal piece is bent, and the assembly can wiggle sits 'sloppy' in the hole.
I dont get it, as the electric plug protrudes from one side, and this metal piece protrudes on the other side, so there is no way to snap it back in the hole w/o bending the metal piece.
Can someone help here with getting it back in correctly as well as what else to look for to get this light working?
Thanks!
Old Jul 22, 2009 | 03:52 PM
Andrew149's Avatar
have u checked if your getting voltage out the wire that plugs into it or check a fuse?
Old Jul 23, 2009 | 08:44 AM
hypermoto's Avatar
checked it....nothing. Going to have to trace this back.
Any idea on how to properly get the assembly back in its' original place?
Old Jul 24, 2009 | 10:15 AM
hypermoto's Avatar
anyone know how to get this stupid overhead light plastic assembly back in it's home snug and correct?
Old Jul 24, 2009 | 10:50 AM
rcheing's Avatar
perhaps a few pictures of your problem may help us help you...
Old Jul 27, 2009 | 11:02 AM
rcheing's Avatar
Hey man, check out this post by Andrew, it has to do with sunroof switch fixing but it includes some instructions on the courtesy light.
Old Jul 28, 2009 | 08:57 AM
hypermoto's Avatar
thanks, but I am having issues with the light under the visor
Old Jul 28, 2009 | 09:37 AM
rcheing's Avatar
OK, that's not the "overhead courtesy light", what you want to fix is referred to as the "vanity light" and according to ALLDATA Online (an application we use at my shop) it is integrated into the sunvisor. When you need to repair it, the whole sunvisor must be replaced. I ran a search using my car as the vehicle type. For the future, can you add your vehicle type, model, engine size, anything you think will help us, etc... to your signature? You can change it in the control panel. Here's a picture of what ALLDATA gave me:
pmis91
Aug 26, 2012 02:01 AM
AndyA4C
Jul 22, 2009 11:37 AM
eliTTe
Sep 25, 2007 10:09 PM
0Face
Jun 26, 2007 03:55 PM
