Overheats only on load
Old Feb 7, 2013 | 05:14 AM
Jim_Coupe's Avatar
Default Overheats only on load
Hi,
I have a problem with overhetaing my engine. Im running on a FrankenTurbo setup so im boosting alot. But when im pushing to much it overheats.
When it is overheated the hoses are very swollen and stiff and hot. Its almost like the coolant fluid is stucked somewhere. I have changed the thermostat to a new one but no change. It is almost like there is a plug in the system. The water pump was changed 2 yrs ago.
when i put my hand on the hose after the water pump. (the output from pump) its cool. almost as if the fluid stop in the pump.
Could this be bad pump? Some ppl are talking about blown head gasket puming gaspockets into the system. When i rebulded 2yrs ago the engine i re-used my old steel head gsket. som say this is not good?
If you have a clue leave an answer.
Old Feb 7, 2013 | 07:54 AM
jonbonesjones's Avatar
Moderator
bad pumop, id say. pull the hose afrer the pump and turb the car over. Does coolant spray out?
Whne you did the rebuild did you atleast deck the head and block? Its not so much re using a head gasket is bad, its not having the head and block sit flush together that causes problems.
Old Feb 11, 2013 | 06:41 AM
Jim_Coupe's Avatar
didnt really understand.. You mena disconnect the hose comming out from pump and start engine?
Old Feb 11, 2013 | 06:54 AM
tofast2belast's Avatar
no he means did yo take the head to a machine shop and have the cylinder head shaved/milled to make the head surface flat and straight.
Old Feb 11, 2013 | 07:51 AM
Jim_Coupe's Avatar
No i did not.. Its an AEB head and an ANB block :S
Maybe i should go to bottom with this and take the head to my local machineshop, change gasket and pump... uhh.. Its a nice franketurboed Audi i should be a shame to just sell it as it is.....
Old Feb 11, 2013 | 07:53 AM
Moderator
Theres your problemright there, not decking causes all sorts of unexplainable problems. Worked on a chevelle, had the same motor rebuilt 3 times because of over heating. Never decked the head. Once it was decked and done right, it works right....weird
Hows the intercooler? Its possible your just overflowing it and its not able to cool all the air and your shoving hot *** air into the engine.
Old Feb 12, 2013 | 08:24 AM
Jim_Coupe's Avatar
that is possible but i drove this car last summer in 28 dregrees celsius without problems.. boosting 2.2bar on my FrankenTurbo. its -5 celsus here in sweden now.
Old Feb 12, 2013 | 08:27 AM
Jim_Coupe's Avatar
Well thank you i guest ill have to machine my head then.. aw crap.. now im thining shall i keep this car... No one buys a car with bad head alignment even if i have H beams and a Frankenturbon and E85
Old Feb 12, 2013 | 12:35 PM
hartsoe1's Avatar
Yes, I think you should eliminate the water pump as the problem before you pull the motor. Remove a hose on the discharge side of the water pump, and turn over the motor with the key and starter, but don't let it start, just see if coolant is pumped out. If not, that is your problem - the pump. Only try this with a cold motor and coolant.
Old Feb 12, 2013 | 12:44 PM
hartsoe1's Avatar
Smile
[QUOTE=jonbonesjones;1423875]Theres your problemright there, not decking causes all sorts of unexplainable problems. Worked on a chevelle, had the same motor rebuilt 3 times because of over heating. Never decked the head. Once it was decked and done right, it works right....weird
JBJ, I hear you, but really, comparing anything on a historic US of A V8 and a German 1.8 has got to be a stretch.
