P0455 / Large leak. Help?!
Old Jun 28, 2008 | 05:51 PM
RedShoeRider's Avatar
Default P0455 / Large leak. Help?!
Good Evening, all:
The car: '99.5 A4 2.8 quattro.
The code:
Address 01 -
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D04
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
16839 - EVAP System: Large Leak Detected
P0455 - 35-00 - -
Readiness: 0000 0000
The problem: Where do I begin troubleshooting this? Is there a "most common culprit" on this chassis/engine?
Thanks!
-Red
Old Jul 1, 2008 | 10:26 PM
Default RE: P0455 / Large leak. Help?!
Anyone?
Beuller........Beuller........Beuller.......
Old Jul 1, 2008 | 10:42 PM
Tweaked's Avatar
Honestly, the gas cap is the most common for a large leak.
Perform a visual inspection of your EVAP system, look for torn hoses or even a crack in your gas tank.
Run the LDP and listen for leaks. Your EVAP purge valve might even be stuck open. Just start and diagnose systematically.
plinko89
Nov 26, 2018 06:03 PM
Gfunk176
B7 Models
Mar 25, 2011 09:41 PM
plinko89
Jan 11, 2011 10:47 AM
jerkyboy
Jul 27, 2010 12:15 PM
Bass402
Jun 12, 2007 12:23 AM
