P1300 & P0301, engine running rough, it is not Coilpack or ICM. What else?
Old Apr 17, 2010 | 05:27 PM
AK_47's Avatar
Default Update: P0301 switched, engine running rough, it is not Coilpack or ICM. What else?
Car: 1999 Audi A4 1.8T (Quattro)
This week my car started to run rough during acceleration (just fine when idling), engine seems to be trembling. I searched and read through and people suggested either Coil Packs or Ignition Control Module replacement in the past and it seemed to work.
I bought and tested a new coilpack still got the same codes. Purchased and replaced the ICM but now the code "changed" to P0302 (cylinder 2). Does that mean the replacement Ignition Control Module is faulty?
Also replaced the spark plugs to new.
What else could possibly be wrong? If you have any thoughts on it please share.
Thanks.
Old Apr 17, 2010 | 07:16 PM
AK_47's Avatar
Updated above but after replacing the ICM engine code changed from cylinder 1 misfire to cylinder 2 (P0301 to P0302). If all else fails I might just have to take it to the Audi specialized mechanic.
Old Apr 17, 2010 | 07:49 PM
MartinCieslak1's Avatar
Was it a new ICM ? it could be faulty
Old Apr 26, 2010 | 02:19 PM
AK_47's Avatar
The ICM that I purchased was used from Phill's Auto in CO and yes it was DOA (confirmed by my local mechanic) but the seller refused to even talk about it or resolve the issue so I filed a report with the CC and they will take care of it...
Ended up buying a new ICM for $147 shipped from autohausAZ.com seems like a great business that takes care of its customers.
Thanks for the reply Martin
Old Apr 26, 2010 | 06:32 PM
joenelson7687's Avatar
Might be a good idea to still check the gapping on the plugs...
Old May 3, 2010 | 01:17 AM
AK_47's Avatar
Changed the ICM, car drives perfectly. BTW is this true? http://www.goapr.com/products/apr_exhaust_a418t.html I have that exhaust (was previously installed) and it gives that much power without any chipping etc?
Old Feb 29, 2012 | 05:15 PM
Shuya'99's Avatar
The car you have actually has two ICMs and if its not one of them, check your compression either by hooking it up to a computer with the diagnostic software to give you a compression check OR, if you have a good ear, Disconnect all of your ignition coils and crank the ignition. It wont start but the starter will still turn and what your listening for is steady rhythm. If theres a consistent sound of a mis-rhythm, you have bad compression and that can cause a misfire.
Also, try swapping a fuel injector from a cylinder thats firing to the one that isn't and see if the misfire follows the fuel injector.
Old Feb 29, 2012 | 05:21 PM
M5S5's Avatar
Tech Certified
This post was from 2 years ago!
Old Feb 29, 2012 | 05:44 PM
MetalMan's Avatar
Not only is this thread super old, but you may have misread the first post of this thread - the engine is a 1.8T, so it only has one ICM. Otherwise this is potentially good advice (except the OP already fixed the issue...).
Old Mar 1, 2012 | 10:01 AM
Shuya'99's Avatar
lol i didnt even look at the date haha!
I have the same car but its the 99.5 and it has two ICMs for whatever reason.
My mistake, sorry lol
LUNESTA PM
Nov 21, 2014 10:16 AM
P.Sapper
May 6, 2012 08:41 PM
cdpoppert
Apr 19, 2010 12:42 PM
spatula
Apr 30, 2009 07:45 PM
