performance coil packs?
Old May 27, 2012 | 05:21 PM
moneyfresh's Avatar
Default performance coil packs?
hey guys, started the a4 quatttro today found it was running a bit ruff, took it down the street turned around and checked the engine, misfiring on 1 and 4, so i need some new coils seen a couple for 20bucks oem that is, just wondering if there is any performance coils maybe made of ceramic? thanks guys
update: seen some Hitachi "E" coil packs wondering if anybody tried these? ECS tunning sells a stage one for 150$ with 4 new coils seals and new stainless head bolts.
update: decided to go with the OEM rev. R coilpacks with NGK plugs couple of dyno tests done found on another audi fourm,
http://www.audizine.com/forum/showth...38-spark-plugs
red = OEM rev R coilpacks with Bosch plugs
violet = Okada coilpacks with NGK plugs
light blue = OEM rev. R coilpacks with NGK plugs
Old May 27, 2012 | 06:06 PM
morpheous's Avatar
Call your local Audi Stealership,there is a coil pack recall in effect for our Audi A4 b5's.
Get the new batch,replaced free of charge.
Old May 27, 2012 | 06:10 PM
moneyfresh's Avatar
ill give them a call tommorow dought they will replace, had motor swap done
Old May 27, 2012 | 06:33 PM
ImTheDevil's Avatar
It all depends on the VIN - if yours is in the recall range and it hasn't been done, you'll get them.
Old May 27, 2012 | 06:37 PM
moneyfresh's Avatar
alright, if it has not been replaced, do i need to drive it in with 2 bad coils :S:S:S:S:S or can i just pick them up?
Old May 27, 2012 | 06:40 PM
CCA4's Avatar
They probably won't do the recall swap unless you bring the car in. How far is the shop from your house? I think you could prolly get away with limping a few miles on two bad coils but I wouldn't drive much further than that.
Old May 27, 2012 | 06:42 PM
moneyfresh's Avatar
well thats another problem,,, its about 20 or 30 kms, highway, and if they wont recall it, double that..
Old May 27, 2012 | 09:32 PM
morpheous's Avatar
ummm..how about calling them with your vin handy to give to them,over the phone,before you drive 20 miles for nothing?
Old May 27, 2012 | 09:36 PM
moneyfresh's Avatar
did the online search with vin, its not covered in the recall, was thinking about calling them to price out the revision R coil packs, anyother suggestions? i heard the revision R has more spark but more prone to pop, as the revision D coils have less spark and less prone to pop
Old May 28, 2012 | 09:31 AM
moneyfresh's Avatar
got the revision D coils everything is running smooth,,,,,, for now :P thanks guys!
