Please Help...Code reader connect problem
Old Feb 7, 2008 | 11:55 PM
AlfaSpider's Avatar
Default Please Help...Code reader connect problem
I just bought a CAN OBD2 diagnostic code reader and when I try to connect to my 1998 A4 1.8T I get a communication protocol not found. Make sure your key is in the on position and try again.
This happened at Good Year to but I just thought the guy trying to connect was just doing it wrong or something. I have done searches on this site but have come up empty so far.
The only thing that I know of that is not stock in the motor is I get about 16 pounds of boost. The guy I bought it from said it had a software upgrade.
Any help would be much appreciated.
Thanks,
Kelly
Old Feb 8, 2008 | 03:24 AM
A4speed's Avatar
Default RE: Please Help...Code reader connect problem
does your car start?
also, you have the stock engine, its just been chipped so now your turbo produces more boost.
Old Feb 8, 2008 | 12:23 PM
AlfaSpider's Avatar
My car runs awesome. Last year my check engine light came on and I found a guy to come over and plug in with his laptop to tell me whats wrong. It was my evap canister. I have replaced that but never got my engine light reset.
My tabs have now expired because I cannot pass an emission test with that light on.
Any ideas?
Old Feb 8, 2008 | 02:24 PM
A4speed's Avatar
i would say that the connecter pins are messed up since you can't get a read from it. thats the only idea i can think of, it should work.
Old Feb 8, 2008 | 03:51 PM
AlfaSpider's Avatar
Umm...Well I will try it out on one of my other cars and see if it works.
I also read somewhere that it could be my after market stereo. It said it unhook it and try. I think it was left on when I was trying to connect so I will try just turning it off first.
Kelly
Old Feb 8, 2008 | 06:21 PM
CRAZYHAWK's Avatar
If disconnecting the HU doesn't help, try using
a non CAN-Bus Code Reader
jhawk
Jun 15, 2012 08:12 PM
mrk3cobra
May 8, 2009 02:04 PM
kerosene
Dec 10, 2008 01:30 PM
uruk
Nov 16, 2007 07:36 AM
za3toor
Oct 23, 2007 09:32 AM
