please help joey nelson!!!
Old Oct 14, 2010 | 09:36 PM
briesa4's Avatar
Default please help joey nelson!!!
I am currently helping one of our members that is stationed in TX
He has recently done his Cam Chain Tensioner with one purchased from ECS.
Since he has had valve tap that disipated with an oil change.
He had codes today
P0301 Misfire cyl 1
P0303 Misfire cyl 3
P0304 Misfire cyl 4
P0353 Ignition Coil “C” Primary/Secondary Circuit
The valve tap returned as well
The only resolutions I have found so far:
Replace the plugs DONE
Maf Recently Replaced
Please help asap he needs to be home in Maryland ASAPPP
Old Oct 14, 2010 | 10:20 PM
joenelson7687's Avatar
Here's something else that just happened...I gave it some gas and the "valve tap" followed the RPMs but as soon as the RPMs dropped back down to idle, the tick went away for about 2-3 seconds and then resumed....i have no clue what that is. I just bought the new tensioner from ecstuning. I thought it was put on correctly cause the car ran fine...a little valve tap but it went away as the car warmed up and i did an oil change. Is it possible it inst on correctly? I need help guys. I just got out of the army and I'm trying to get home to see my mom before she passes away. I'm so desperate....
Old Oct 14, 2010 | 11:17 PM
FASTER's Avatar
Tech Slut
How many miles are on the new tensioner, they make noise for awhile until they are broken in.
Old Oct 14, 2010 | 11:27 PM
briesa4's Avatar
about 650
Old Oct 14, 2010 | 11:31 PM
twoeightquattro's Avatar
i wish i knew 1.8's
anyway, best of luck, and I hope you make it home!
Old Oct 14, 2010 | 11:59 PM
I know they make noise but this noise isnt the same...its either valve tap or lifters type of noise
Old Oct 15, 2010 | 12:06 AM
maybe a shot in the dark, checked oil pump or something similar? bad oil pump or too low/too high of oil pressure could cause a knock.
Old Oct 15, 2010 | 12:38 AM
dstrawn's Avatar
i recently replaced mine in my car as well. i had the same codes and we couldn't figure it out so we took it to the stealership and they calibrated the sensor on the tensioner
Old Oct 15, 2010 | 12:50 AM
The actual VVT sensor?
Old Oct 15, 2010 | 01:09 AM
dstrawn's Avatar
this is off of the sheet they gave us "set cam adjuster timing to audi spec"
