Possible Bad Injector?
Old Aug 7, 2013 | 11:06 AM
xxNeverG1veUpxx's Avatar
Default Possible Bad Injector?
Audi A4 1998 1.8T Manual Quattro
My car was running great until yesterday when I was pulling into my garage. I go to get up the driveway and I killed it, so I started it again and put more gas and got up the driveway but my check engine light when on briefly and went off. I turned my engine off and went inside. That night I go to get something to eat and my car had the CEL on so I VAGcom'd it and it brought up two codes.
P0300 Random/Mulitiple Misfire
P0301 Misfire Cylinder #1
So I switch my coil packs around (I have the 034 Motorsport ICM delete Kit Installed) and no change. I switch my spark plugs around and still no change. I cleared the codes in between each process. I then start the car and pull the plug on Injector #1 and the car sound doesn't change.
I ordered some used Fuel Injectors 4 of them for $60. They will be here in the next day or so. Is there anything else I should be looking for in the meantime? Is the injector the cause of this? Leaking Intake Gasket?
Any help would be appreciated. Thanks ahead.
Old Aug 7, 2013 | 06:44 PM
Expplucky's Avatar
id check cyl compression too, you should have started with running seafoam through the tank if you suspected an injector.
Old Aug 8, 2013 | 10:56 AM
Actually pulled the MAF sensor and now the car is running fine. I had another MAF sensor laying around and swapped it out. Running on all cylinders again. Lol.
rustydavis
May 25, 2012 09:20 AM
ungawa
Aug 9, 2010 10:16 PM
flyboy
Jan 1, 2006 04:12 AM
aRIf
Oct 24, 2005 05:31 PM
Jeff
Oct 14, 2005 03:16 AM
