Possible O2 Sensor issue 2001 A4
Old Jan 6, 2011 | 09:10 PM
chrfe's Avatar
Default Possible O2 Sensor issue 2001 A4
I have some kind of issue with a 2001 Audi A4 1.8t. I recently replaced all the coils because 1 was bad. This made the car drivable, but I am still getting the following codes. I tried driving very fast for a while in case the sensors were carboned up, but it did not help. I have attached some screen shots of some logs. Does it seem like the Pre-cat o2 sensor is bad?
Thursday, 06 January 2011, 19:19:33
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4B0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 16251
Work Shop Code: WSC 40907
4 Faults Found:
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
Attached Thumbnails Possible O2 Sensor issue 2001 A4-group034.jpg   Possible O2 Sensor issue 2001 A4-vaglogs.jpg
Old Jan 6, 2011 | 09:42 PM
BaconBait's Avatar
Yes, it looks like the pre-cat sensor is bad. B1 S1 is pre-cat. B1 S2 is the post-cat sensor. They're usually under $150 online. Just make sure you check your engine code and get the correct one.
careercadaver
Aug 19, 2010 08:40 AM
rehan1212
Apr 23, 2010 11:07 AM
soldierboy15
Apr 21, 2009 04:42 PM
petedonlan80
Aug 15, 2008 10:18 PM
modset
Jan 19, 2008 11:28 PM
