Power steering or rack?
Old Oct 31, 2010 | 11:47 AM
jeeplover38's Avatar
Default Power steering or rack?
My 97 Audi A4 has recently started grinding/whining when I turn the steering wheel. It is not losing any fluid.
I would like to change it myself if it is the pump. Is this something I can do, or is it something that needs to be taken in for? Any suggestions?
Old Oct 31, 2010 | 01:34 PM
colony777's Avatar
whining USUALLY means your rack is going out
Old Oct 31, 2010 | 03:03 PM
hiwords's Avatar
i've had the rack and pump go out on me. both produced the same whining noise. best way to diagnose the problem is if the wheel gets heavy at a stop and lighter as you go faster or if you rev the car, it's the pump.
if it's the rack, you'll notice a leak on the driver's side tie rod and you should see a lot of bubbles in the reservoir
Old Oct 31, 2010 | 10:06 PM
ImTheDevil's Avatar
Verify the fluid is where it should be. If it is, get in the wheelwell and pull back the boot over the tie rod end. You may find it contains the fluid you were losing as a result of a shot rack seal or joint.
Inte
Aug 8, 2014 01:26 PM
matant01
Dec 31, 2007 04:21 PM
jimmyt853
Jul 9, 2007 05:28 AM
crazyching
May 5, 2007 06:59 AM
