PROBLEM: WHEN IN NEUTRAL.....please help
OK, I have an a4 and its stick, Now somethimes when I put it in nuetral the pointer bounces below the one thousand rpm mark and you can hear my engine make a wierd noice. It will then bounce back up and goes back to normal again. Does anyone know whats going on.
Thank you...............
dont know really what you mean? when in neutral the engine will want to idle and that is less than 1000rpm. and what do you mean by bouncing back? and whats normal? do you mean shifting to neutral, than letting it coast, than shifting to gear and letting the clutch out?
Yeah, when I put it in neutral before stoping at a red light the pointer should slowely go down to 1000rpm or a little less. Sometimes mine will go below really fast and then the engine will sound like its about to give out or shuts off, but it will quickly go back to normal.... Hope you can understand what im saying...... Thanks
It's like that all the time. I'm convinced its the tb control valve somehow, getting some vagcom errors on it when i try to see the raw data from the sensors..
Try using some solvant and clean the throttle body, hoses and air filter.
