Problems after seafoam
Old Apr 22, 2009 | 05:09 PM
  #21
nitro_rider2001's Avatar
so a few questions.. whered you get the write up on the 2.8?? all i have found is for the 1.8t and i dont know which vac line to hook it up to.. also, I wanted to do the oil, so how long should i drive it for b4 an oil change after seafoaming the oil?? like 50 miles or what? also I am due for spark plug change.. has anyone used pulstars here.. i know they are 25 each but hell, why not try something new that has a ton of hype about it right... and does anyone know where i can get a thin wall spark socket for the v6s lil *** spark plug holes?
Old Apr 22, 2009 | 07:04 PM
  #22
ImTheDevil's Avatar
Originally Posted by audiA4gm
I Was considering seafoaming, and my 2.8 could definitley use it, but I'm pushing 176k so it just doesn't seem like the best idea given the miles.
Hell I last seafoamed at 166k and did it exactly how A4Cragman did - half in the oil, half in the vacuum, full can in the tank. Worked like a charm. No worries.
Now to partially threadjack (but not really since it's about a question from the OP anyhow):
A4Cragman, I saw I missed a couple calls from you - I don't know the exact spec for the cluster bulbs, but to remove the cluster you just pop the top trim piece off the column back where it meets the dash - not the column trim that actually encloses the column, but the bezel-like piece where the column enters the dash. Pop that off, undo a couple screws, and pull the cluster out. You'll need to bring it out (if I remember right) at an angle, bringing out the end with the oil temp gauge first, reaching in to unplug the cables, and then bring it the rest of the way out. Install is the reverse.
Old Apr 22, 2009 | 07:44 PM
  #23
A4Cragman's Avatar
Yea man, the calls were about the seafoam job, I wasn't sure which vac line it was but got it figured out after an incredibly tedious search job on the forum, its no wonder noobs never use it, its hard business!
Cool, thanks for the info on the cluster removal. I'll try to get to that this weekend, its driving me nuts not being able to see half of my speed gauge.
Old Apr 22, 2009 | 08:32 PM
  #24
ImTheDevil's Avatar
when you get the cluster out and check the bulbs, let me know if you have the right ones. If not I'll send you a couple - last summer we cleaned out a lot of miscellaneous parts from the Audis at the local salvage yard, and I have at least 20 cluster bulbs. I can send a few to you if you need them.
Old Apr 22, 2009 | 09:21 PM
  #25
Prizmatik's Avatar
Now that is a cool Audi enthusiast--> ImTheDevil...lookin' out for A4Cragman. Willing to hook him up with some bulbs. That is nice to see.
Old Apr 23, 2009 | 03:08 AM
  #26
A4Cragman's Avatar
Man, I wish my local salvage yards even had B5s to pick through. The only Audis at any of my local salvage yards were the old school 80's era, and each of the yards had 2, maybe 3. What other parts did you salvage? Did you happen by a silver passenger side headlight sprayer cover by chance? Mine disappeared a while back and the stealership sells them for 15 bucks unpainted and when I called a paint shop, they wanted about 70 bucks to paint that 4 square inches so if you have or ever find one that is already silver, hit me up
I haven't bought the new bulb off ECS yet that I had found though, so if you could hook me up with one or two of them, that'd be fantastic. I'd save me having to place a 99 cent internet transaction at least
Old Apr 23, 2009 | 03:25 AM
  #27
Midniteoyl's Avatar
Duplicolor.. $5.25
Old Apr 23, 2009 | 02:43 PM
  #28
A4Cragman's Avatar
Originally Posted by Midniteoyl
Duplicolor.. $5.25
Considered that, but matching silver paints is super tedious. Unless you've used a specific shade of Duplicolor that has worked well, then I'm all over it. Do share if you know the right shade that'll match my silver
Old Apr 24, 2009 | 02:18 AM
  #29
Midniteoyl's Avatar
Blue Silver LB5S or Reflex Silver LA7W ?
Your only doing a small part...
Old Apr 25, 2009 | 01:17 AM
  #30
A4Cragman's Avatar
Cool, thanks man. I'll look into it this weekend and see if i can make it work.
