Question about brake caliper line connection, leaking...help
Old Jan 1, 2011 | 06:57 PM
tkltian's Avatar
Default Question about brake caliper line connection, leaking...help
Hi I'm kind of new for working on the Audi A4 B5. Learning ...
My car is Audi A4 B5, 1999, pre-facelift, Quattro, 1.8T.
I just replaced the rear driver's side brake caliper. I screw the brake line into the new caliper, pretty tight (almost the tightest I can do with a small wrench). The brake line is not banjo type, it's kind of just a threaded pipe with hole in the middle. The front of the connector I think is tapered for a metal to metal seal I guess.
But now everything is back in place, the connection between the brake line and the new caliper is leaking. When the pressure is up the leak form a squeaking thin jet sprayed from the connection.
So my question is, what is the proper way of doing it? Should I just tight it up really tight? I am a little bit afraid to strip the screw.
I appreciate any help or suggestions.. Thanks.
RicksAUdi4.2
Oct 14, 2014 11:57 PM
JimmyWRE
Oct 14, 2011 08:51 AM
ImTheDevil
Apr 19, 2008 12:36 AM
thenext54
Jul 7, 2007 10:01 AM
noot74
Jan 20, 2007 07:43 PM
