question before chipping
Old Jan 19, 2009 | 09:10 PM
less_of_me's Avatar
Originally Posted by mrbloink
Is there a good DV that people could recommend?
You can get the 710n from your local dealer. It is off a TT and it will be able to handle the boost you are going to make. If you feel like spending more money (which you don't need to) you can do a search on these forums for "diverter valve" and I'm sure any other options will appear.
Old Jan 19, 2009 | 09:45 PM
A4speed's Avatar
yeah, theres the forge 007 and APR R1 dv's that both work well if u dont want the 710n.
Old Jan 20, 2009 | 12:27 AM
ghost6303's Avatar
if you have the 710n valve, install it in the direction that your stock one comes off. if you have a nice aluminum or steel DV, install it in whatever direction holds the most pressure, usualy that is pressure hose to the side of the DV, not the bottom of the DV. but they are all different. really it doesnt matter much for your setup.
Old Jan 20, 2009 | 10:00 AM
mrbloink's Avatar
Ok thanks for all of your help.
So i should just order 4 spark plugs and a new DV. well besides sending out my ecu. I shouldn't need new injectors correct?
Oh and what heat rating should the spark plugs be. I was thinking about 6?
Old Jan 20, 2009 | 03:14 PM
onepoint8tee's Avatar
NGK BKR7E or 6E @ .028
Get a used aluminum dv like a Forge for a little more money if you can. It lasts forever and there are no rubber guts to tear.
Old Jan 21, 2009 | 12:36 PM
mrbloink's Avatar
I guess i will take a trip to the classifieds.
If I will be replacing my vacuum lines, should i get this done professionally, or if its not to hard, is there a write up?
Old Jan 21, 2009 | 12:53 PM
AutoUnionFan's Avatar
do the vaccuum lines yourself, just pull out the old braided lines and replace with new lines - not that hard
Old Jan 21, 2009 | 01:11 PM
  #18
mrbloink's Avatar
EDIT:
Never-mind, stupid question.
Thanks everybody for all of your help.
A_Plus_Remodeling
Nov 4, 2009 03:36 AM
thetryal
Oct 17, 2007 07:08 PM
joelml
Jun 12, 2006 07:01 PM
MeanAudiA6
Mar 8, 2006 04:51 AM
cgv988
Apr 20, 2005 11:58 PM
